quick gsr swap help
Juanlamonaca
i bought a gsr and i will be swapping it into my 98 hatch. my question is can i use all the hoses from my old motor
no your gonna need Bseries upper and lower.... Make sure you get hose clamps that screw cause the hoses will be a bit bigger then the D series just make sure you tighten them down as tight as you can and you will be ok.
you are going to need the b series hoses
AND if you get the oem 99-00 civic Si radiator you won't have to worry about tightening the hoses to fit the smaller radiator.
it is better to go with the right stuff rather than have the hose blow off and wreck your motor.
Radiator is about 200 at honda.
not true, the lower hose will work, i sprayed some wd-40 on the water neck and it slips on with a little effort. The upper has to be changed to an integra, i cut a 90-93 to fit, works great.
The motor should come with all the hoses that stay on the motor, hoses coming from the car will go to there respective locatations.
