Radiator & Radiator Fan Dilemma
Discussion in 'Civic and CRX - EF' started by Vtec Veteran, Apr 6, 2011.
  1. Vtec Veteran
    Vtec Veteran New Member
    Background:
    This is a half radiator from an EG, installed in an EF during a Bswap.
    1) Previous owners chopped the wirings to the fan wen it ran a D16 motor. Now that i'm re-wiring I need some confirmation.
    The fan needs to blo air TOWARD the motor right? (switching polarity switches fan direction
    2What radiator do you guys use for your Swaps. Mine seems to have the hose pressed against the oi pressure switch which i'm sure is not heatlthy for the hose.
    Hose currently being used (or attempted to be used,) is off a civic EG which is where the motor came from.
    3) Lastly,what radiator hoses should i use if i'm to stay with this radiator?
    Naturally, it goes without saying....the car isnt running yet & wont be for a while so its not wise for me to go to the local store, park outside & test hoses.
    Any/All help is appreciated
