seriously what are you asking?
are you trying to figure out what your spring rates are? what are the numbers on your springs? what kind of springs? need more info.
Springs are measured by their spring constant in either lbs/in or n/m. If you know any basic physics you know that F=kx, where F is the force, k is the spring costant and x is the amount the spring is compressed.
This means that if you have a 300lb/in spring on your car, that for each inch it is compressed it will push up with a value of 300lbs. Therefore, 1 inch = 300lbs, 2in = 600lbs, etc.
