rear disc brake conversion?
c-rex-beat
yeah, it's a vtec.
What cars can I use the rear disc brakes from to fit my 89 rex? My friend has a del sol and I wanna know if they will work or not before I tear it all down for nothing.
90-93 integra fits on 90-91 so im sure they will fit the 88-89 but im not 100% sure. You will also need a prop. valve and e brake cables from the teg as well
90-93 will I have already done that and it bolts right in the only problem was with the e brake cable my hatch was a perfect match for the 4 door teg
haha if you want the easiest way just go with the crx si... the 91 si came with front and backs
