Rear disc brake conversion
Discussion in 'Civic and del Sol - EG and EK' started by Scorpin, Aug 28, 2006.
  1. Scorpin
    Scorpin Junior Member
    I have an opportunity to buy a rear disc brake set up from a 96 EX, cables, everything except the master cylinder. I just need to know if the rear disc brakes from the 96 EX will work with my 94 DX, and what else if anything would I need to get beside the master cylinder. Do you think I should upgrade to a vtec engine also, My girl drives this most of the time, and isn't into the power like I am. With me the faster if goes the better. Hence the reason I drive a Eagle Talon TSI AWD.
    Thanks
  2. welfare
    welfare Ancient Member
    New York
    the rear disc brakes will bolt right up to your chassis, you don't need to put in a new master cyl, all you need is the rear suspension (complete) from the 96 ex, the e-brake cables and the brake hoses from the 96, you don't need a master cyl or anything else.
  3. phunky.buddha
    Dallas / Fort Worth, TX
    You don't NEED the bigger master cylinder, but it is recommended. Look for the 4040 proportioning valve too so you get the correct front/rear brake force split.
  4. florida
    florida Acura 1.6EL Premium
    CALIFORNIA
    Uhh, the 96 EX never came with rear disk brakes.
    They might have been swapped from a 99-00 Si.
  5. SlowEgg
    SlowEgg I need paint.
    Omaha, NE
    Thats what i was thinking. If you haven't already, its a good thing to get new pads/rotors as well. And yes you do not NEED the master cylinder, but its strongly encouraged to get the proportioning valve. although i have seen some rear disc swaps go without them.
  6. dthug
    dthug New Member
    the rear dicks from 96+ will not just bolt up. IIRC correctly the trailing arm is longer in the eks then the eg. if you can get rear disk from a integra they have the same parts and almost everything is interchangable and it bolts right up with no modifications
  7. 96EKB18C5
    96EKB18C5 New Member
    True dat! I'm livin proof, i own a 96 ex coupe and I'm stuck with those hiddeous DRUMS! I also heard any 94-01 integra rear discs will bolt up.Anyone know where to get'um cheap?
  8. 92dxhatch
    92dxhatch Senior Member
    nor*cal
    i don't think integra rear disk setups will work on a 96 ex either, the trailing arms on the 94-01 integra are identical to an EG, except the itr's. so if the trailing arm on an EK is slightly longer, the integra's won't work either.
  9. arondude20
    arondude20 New Member
    ok i have some stuff and i need to know for sure. i have a 93 civic dx and i have the rear trailing arms and upper and lower control arms from a 92 intergra and also the wheel bearing hub assembly. do i just need to swap the disc hub on to the civic trailing arms, or do i need to swap the trailing arms also form the integra ?? someone please help !!! also i dont have axcess to a dc integra so that is out of the question.
    also a side note what about the front brakes will swap from a 92 integra to a 93 civic dx ???
  10. Scourge
    Scourge Future swapper
    Sherwood Park, AB
    I thought the trailing arms were the same length but the lower control arms (LCA) were longer in the EK (compared to an EG).
  11. custompainter
    custompainter drive it like U stole it
    central CT
    hey guys i have the brake conversion in my 99 dx coupe
    i used 94-00 teg rear end and bought a nice set of billet lower control arm my stock would of worked but i got the new ones anyway and yes the lower control arms from the teg are shorter so you have to switch them for the civic's arms
    everything else is a direct fit one thing i didn't do was anything to the master cylinder
    my braking is working fine and trust me i drive the car hard
    but thats on you if you want to do it
  12. custompainter
    central CT
    o-yeah almost forgot be ready to go to the parts store for new bolts they lock up and brake off in the bushings not a fun thing to mess with
  13. lightdrinker
    lightdrinker Got Rice?
    silverdale, wa
    i just got a 96 civic coupe HX i think, i have a 1990 integra that i'm parting out, will the rear brake set up on the integra go onto the civic? or does it need to be from a 94-00 integra?
  14. austin20110
    austin20110 New Member
    Northern Va
    LMAO!!!!!!!!
    way to threadjack noob
  15. lightdrinker
    silverdale, wa
    are you a fag?
  16. austin20110
    Northern Va
  17. lightdrinker
    silverdale, wa
  18. YBLEGAL
    YBLEGAL Regular Member w/ Cheese
    NW Indiana
    lol.
    My '00 civic ej8 (ex) i converted for rear disk uses the 90 integra rear spindles and calipers. the trailing arms dont bolt right up but they're old and shitty compared to my 2000's.
  19. lightdrinker
    silverdale, wa
    k so did you use those arms off the 90 teg or the original one from ur car?
  20. YBLEGAL
    NW Indiana
    Parts list -> YBLEGAL - 5th Upgrade Session
    I used my 2000 trailing arms, 2000 Si parking brake cables, 1990 integra spindles, and 1990 integra calipers (and custom brake lines).
