what year teg can I get a rear sway bar for my 5g civic sedan? also...I need to do my front brakes...is it possible to swap teg or civic ex/si disc's to the front of my sedan?...I know I would need the master cylinder...my car does not have abs...and my front rotors are almost shot(had them turned the last time about 10k ago) If its possible I want only to get the monting hardware and buy new disc's and a caliper rebuild kit....just wanna know what will work
You are right the 94-97 integra suspension and brakes will work on a 5th gen civic! Nothing 93 and older will fit! The 94-97 integra was based on the 5th gen civic's!
youll have to drill holes to mount them. anyone know what all you need to put the 4 wheel discs from a 3rd gen teg to a 5th gen cx
it could work... a friend of mine tried to put a gsr front sway on his 96 civ 2door... wasnt happenin, the linkage was hitting it, but i dunno about a sol
I think the list is: hubs rotors calipers brake lines e brake cables reccomended: Integra master cylinder/brake booster ect. Please correct me if I am wrong.
