recommended fuel pumps for 91crx
rexaddict
turbo ex
i have a 91 standard crx with a bad fuel pump and i was looking to get an good aftermarket pump.
i will be doing a swap at a later date and would need this pump to work with both systems
very thankfull for any and all advice
thank you
is there n e others that are good and do i need an adjustable regulator with the walbro
if i do n e recommended
bosch makes a decent oem replacement pump if that's all that you're looking for...but if it is hp you are after and you need more fuel go with walbro like blanco said.
thanks for the info
ive taken mine out a couple times till i realized it was the main relay(courtesy of handaswap) but 2 weeks after i replaced the relay the pump dumped
but damn that was a fun 2 weeks
so yeah ill go with the walbro 190
n e one know a good honda tuner in or around Olympia WA
