Red line issue
Discussion in 'Accord' started by 94tuner, Mar 22, 2010.
  1. 94tuner
    94tuner New Member
    I have a 94 accord with the f22b1 and the red line on the gauge says a little over 6k but mine starts to bounce at 5k. Thanks.
  2. 99sidude
    Ohio
    Are you running the correct ecu? Any check engine lights? It could be an ignition issue, though the engine will more or less break up at higher rpm's rather than act like it's bouncing off of a limiter.
  3. 34diesel34
    34diesel34 Import Tuner
    USA
    Your plugs may be foul, bad plug wires.
  4. 94tuner
    94tuner New Member
    my friend told me it might be a fuel prob or the selonoid could one of those be causing it?
  5. 94tuner
    94tuner New Member
    Yeah nothing on the engine has been modified so i assumed that the ecu is stock
  6. BrutalB83
    Rochester Hills, MI
    Nothing like redlining that stock Accord engine to show everyone what a badass you are... :mellow:
  7. DESPAIN
    flower mound TX
    leave it to brut.......lol
  8. 94tuner
    94tuner New Member
    my car is slightly modified with mostly bolt-ons exhaust and intake. So its not all stock and i would appreciate it if you wouldnt diss my car and help me with my problem and if not then dont even bother with replying to my thread. Now if there is anyone who can give me good advice on how to fix my car i would appreciate it. Thanks
  9. BrutalB83
    Rochester Hills, MI
    It wasn't so much a diss on your car, but more of a diss on what you're doing with your car in it's present form. It's an un-modded F22. It's not a performance-oriented engine in stock form. Stop beating the piss out of it if you want it to last for any length of time.
    Just a friendly suggestion...
  10. 94tuner
    94tuner New Member
    Well i found out its something to do with the vtec. Does anyone know where i can get a solenoid?
  11. BrutalB83
    Rochester Hills, MI
    Junkyards, Craigslist, E-Bay, and dealerships. If you get it from a dealership be prepared to get butt-raped on price...
  12. 94tuner
    94tuner New Member
  13. BrutalB83
    Rochester Hills, MI
