from a command prompt type shutdown -r -m \\PC Name
If you do it that way, that will pop up a warning on the PC that says warning this is shutting down and wait 30 seconds... If you add -t 05 it will only wait 5 seconds. You also need to make sure that your security options under the local policies for Network Access: Sharing & Security Model is set to Classic, and not guest.
