bigballsmagerki
95 ex
So I am in the process of installing a remote start with alarm on my 95 ex. I got the doorlocks workin with the remote and now just am confused with the ignition set up compared to the alarms wiring. Can someone explain exactly how the ignition works to me?
From what I understand There is main power wire which goes to it, and a main ground up there somewhere. Then when you turn it, the ground cuts and sends power to the starter relay wire and accesory and main running wire... I'm not sure how on I am exactly but Its a guess.
There are 6 wires on the remote start system:
-violet starter output
-red +12v input
-red +12v inut
-yellow ignition 1 output
-pink ignition 2 output
-brown acc/heater output
If someone knows a bit more about this please explain it more in detail. Thanks!
-red +12v input
-red +12v inut
