Removing Ac And Ps?
Discussion in 'General Tech and Maintenance' started by Ractive78, Feb 9, 2003.
  1. Ractive78
    Ractive78 Senior Member
    Virginia, USA
    Does anyone know of a site that has directions for removing my ac unit and power sterring unit? For a 1991 Acura Integra rs.
    Thanks
  2. RENR
    RENR Senior Member
    los angeles
    get the repair manual for your car, that should be your best friend. :D
  3. phunky.buddha
    Dallas / Fort Worth, TX
    Uh... unhook belts, remove pumps and everything attached to them, install manual steering rack?
    :D
  4. SnailOnARampage
    SnailOnARampage Senior Member
    Utah
    If your integra is anything like a 5g civic the steering system will go something like this:
    Take driver's side seat out ( so you can be comfortable while laying underneath the dashboard)
    Remove plastic case around the bottom of the steering column (while you are inside the car)
    unbolt the elbow that holds the steering column to the actual rack/pinion unit. (make sure you make a mental note of where the bolts were sitting before you take them off...so you save yourself a headache when trying to put it back on)
    Next you need to get under the car ( if you have a lift it will make your life a loteasier)
    You need to unhook the cat where it hoooks with the header and pull the whole exhaust system back a minimum of 3 inches.
    Next unhook the shift linkages...on the 5g civic there was a rivet holding one of the two shift linkage pieces...which i had to grind off and weld back later...on the other linkage piece there was a regular bolt (its probably something on the D series engines to save money).
    After you remove the shift linkages and the catalytic system you have to unhook the steering system from the wheels. On the rod that connects to teh driver's side wheel there should be something that will unscrew and let the rod split into two. you need to unscrew that so that you can maneuver the actualy steering unit out of the engine bay.
    after you've done all that you just need to remove the 4 bolts that holds the steering unit to the frame.
    That is pretty much all it takes to remove the steering unit, but you MUST have a buddy to help you to put the steering unit back in. The only thing I would stress is...when your head is in the same place your feet normally sit (under the dash) to pay special attention to how those bolts are positioned on that elbow that holds the steering column to the steering unit...if i had to do it again i would go so far as to use a crayon on it so i could tell which side is up and down and how it was positioned before i took it off.
    hehe sorry if none of this makes any sense
    after you've removed all that, just remember to remove the power steering pump (which is on the engine) and all the piping/fluid containers of the p/s system so you can lose some weight on your car.
    As for the air conditioning everything is very straight forward. You pretty much need to remove the ac pump (which weighs a lot), piping, condenser, and remember to remove the evaporator eventually (which is a serious pain in the ass). the evaporator is a big heavy copper thing located somewhere under the dashboard...probably on the passenger side. most people dont even know it exists.
