phyregod
!!YTINASNI
I need rear lower control arms that have a mounting point for a sway bar. The CX has no mounting points. Now, I installed an ITR suspension on my integra, so I have a set of Teggy Lower control arms with strut bar mount locations.
MY PROBLEM: The shock bolt is rusted into place, pretty damned solid. So solid, in fact, that I broke off the heads of both bolts trying to remove them. So I cut off the lower section of the shock mount and removed half of it, and tried hammering out the bolt with a 3lb sledge hammer. No go. I've soaked it with WD-40 for three days now and still no go. The bolt seems to be rusted all the way through the bushing to the LCA.
Any magic tricks?
Any magic tricks?
