removing the intake mani?
Discussion in 'General Tech and Maintenance' started by MthaFuknGreen, Jan 29, 2009.
  1. MthaFuknGreen
    Lodi, CA
    so i need to replace the main gasket on the intake manifold, the one between the block and the manifold.
    how do i go about removing the intake manifold?
    i plan on doing this tomorrow, so quick replies would be helpful.
  2. cjvictoria
    cjvictoria New Member
    N. Chuck, SC
    get some tools and go to town fucker lol
  3. austin20110
    austin20110 New Member
    Northern Va
    putty knife, and scotch bright... make sure you blow out the ports after your done... would hate to suck that shit into your engine
  4. eg6sir
    :werd: .. just unbolt it.. unhook any sensors, vacuum lines(remember what goes where), unbolt outward->in
    when bolting it back on, start ont he inside and tighen outward
  5. MthaFuknGreen
    Lodi, CA
    i marked the hoses and where they go with different color paint pens.
    putty knife and scotch bright?
    huh?
  6. austin20110
    Northern Va
    to take off the old gasket
  7. MthaFuknGreen
    Lodi, CA
  8. MthaFuknGreen
    Lodi, CA
    the upper nuts were easy as fuck to get off, its the lower ones im having troubles with..
    if i remove the oil filter to make room so i can reach the nuts better, wont hella oil leak out?
  9. austin20110
    Northern Va
    maybe like a quart or so
  10. eg6sir
    you dont need to remove the oil filter.. just need a swivel extension
  11. MthaFuknGreen
    Lodi, CA
    i dont have a universal joint.
    the job was easier than i thought it would be.
    i took the top part of the manifold and the fuel rail and shit which made getting to the top nuts much easier.
    2 of the three gaskets were fucked, the two largest ones. i didnt check the smaller one cuz i dont have that one to replace anyway.
    my car definitely runs a lot smoother, but i can only get it to idle at like 1500 without dying.
    whenever it goes below 1000, it sounds like its gonna die.
    i adjusted the idle and the fast idle thermo valve. it idles steady, but still idles lower when in drive then when in park.
    what should i do next?
  12. klyph
    klyph Dismember VIP
    North Pole, AK
    I think it's supposed to idle slightly lower in drive than park. but it shouldn't be at 1500. Maybe 700-900. Sounds like you may have a vacuum leak.
  13. MthaFuknGreen
    Lodi, CA
    well, when i turn down the idle or tighten the FITV all the way, it idles closer to 700, but then it just dies.
  14. MthaFuknGreen
    Lodi, CA
    so i checked the ecu codes, 7 and 8 popped up which is throttle angle and tdc position.
    whats that mean?
  15. klyph
    klyph Dismember VIP
    North Pole, AK
    It means that your throttle position isn't calibrated and your ignition timing is off. How are you "turning down the idle"?
  16. efhondakid
    Akron-Canton, Ohio
  17. HATCHET_HONDA
    HATCHET_HONDA scottie fizzle
    hobart, indiana
    2 of 3 gaskets??? smaller one? whaaaa???
  18. MthaFuknGreen
    Lodi, CA
    fucking with the idle screw and the FITV.
    thats the third gasket that i was talking about.
  19. klyph
    klyph Dismember VIP
    North Pole, AK
    I'm fairly certain you're supposed to unplug the throttle position sensor before adjusting the idle speed.
  20. MthaFuknGreen
    Lodi, CA
    it was already unplugged.
    where is the system checker harness?
    i cant find it, im looking right next to the ecu.
    is it plugged into something?
