CiViC_SOHC
Ok, I am replacing ALL the gaskets in my D16Z6 before I boost it. Do I need any kind of sealent? What kind should I use. I dunno if I do or not, just checking. Thanks in advance.
alright cool, I will go to honda and get some..I thought I needed someQuoted post[/post]]
Lets see...know nothing about d-series, but on my b18, I had to use hondabond on the rear main seal where the plate bolts to the block, on the mounting of the oil pump, the oil pan, in the corners of the valvecover where the cam caps are, and I believe on the cylinder head coolant discharge going to the top of the radiator. That's about all I can think of.
