Replacing gaskets...
Discussion in 'General Tech and Maintenance' started by 94RedSiGal, Mar 25, 2004.
  1. 94RedSiGal
    94RedSiGal Senior Member
    Massachusetts
    Okay so yesterday, among other springtime projects, I replaced the rubber gasket that goes under the valve cover. I noticed that the old one had some sort of white putty in spots on it. So I made a comment to Airjockie and he said it was silicone... but that it wasn't necessary. So this morning, I am thumbing through my Helms for my integra, and it says to put on liquid gasket on the bends of the gasket. So... do I have to redo this job ASAP? :unsure:
  2. Bns773
    Bns773 Member
    Austin, Tx
    No it will be fine. I didn't put any on mine the past few times I did a swap and it never leaked. If it makes you feel better you can but I wouldn't bother.
    (It also says to replace the transmission mounting bolts after you remove them too and my transmission is still on ;) )
  3. uptowng2ic
    uptowng2ic Member
    NY
    The helms is my second bible so IMO I'd follow the helms manual.
  4. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
    I would re do it, they last forever when you do it. Just put it in the corners, it does not take that much time, and it is more like preventative maintanence.
  5. Canuck 93 Civic Si
    Canuck 93 Civic Si Senior Member
    Mississauga, Ontario, Canada
    If it doesnt leak, dont do it
    If it leaks, do it
    If its not broke, dont fix it :lol:
  6. 94RedSiGal
    Massachusetts
    All rightie then... I'll keep an eye on it for now. I might redo it later in the spring after I finish my roadtrip to Texas...
  7. NotUrAverage_Si
    NotUrAverage_Si Senior Member
    it won't take that long, do it whenever you have an extra 15-20 minutes or something.
  8. driverunknown
    driverunknown Senior Member
    now when you do that, what do you use? RTV? And do you put it on both sides of the gasket?
  9. NotUrAverage_Si
    hondabond works great and yeah I did it to both sides
  10. B16
    B16 Super Moderator VIP
    yay area, CA
    :werd:
    i use teh hondabond
  11. driverunknown
    THnx looks like I'll be doing that on Sunday. HOndabond...at honda dealership? What's the price on the stuff?
