Replacing head-gasket on GSR
Discussion in 'General Tech and Maintenance' started by Arrogant_, Jul 19, 2005.
  1. Arrogant_
    Arrogant_ Member
    Does the coolant and/or oil need to be drained in order to do the replacement properly?
    Any input would be helpful.
    Thanks
  2. kyleirwin
    kyleirwin Retired OG
    Vegas
    i didn't drain the coolant when i did mine, but i would if i did it again. it makes a mess. no need to drain the oil though. it's a cakewalk though, good luck.
  3. sihatchback_RL
    sihatchback_RL Senior Member
    i would with the antifreeze, the oil wouldn't be bothered. Just besure to have A LOT of towels, don;t get water into your cylinders, and square off your head to see if you have any warpage. i would get some ARP head studs too....but it all depends on you and your budget. good luck bro
  4. brian11to1
    brian11to1 Senior Member
    sqaure the head and block. cleanlieness is key
  5. Arrogant_
    Arrogant_ Member
    Thanks to all those who replied.
    Arro..
