Replacing Rear Brakes on 1996 Honda Accord Trouble, Rounded Bolt Head Removal
Discussion in 'Wheels / Suspension / Tires / Brakes' started by Chy9853, Jun 26, 2014.
  1. Chy9853
    Chy9853 New Member
    Hey I need some suggestions on how to remove a rounded bolt head on the rear brake caliper on my 1996 Honda Accord. I went to replace the rear brake pads and had no problem removing the bottom bolt from the caliper but the top one was rounded off. It is a 12mm bolt and I cannot get it off. There is no space to do much to get it off which makes things more difficult. Any suggestions on how to get this thing removed? Like I said it is in a tight spot. Any ideas are appreciated. Thanks!
  2. Briansol
    Sometimes, you can take a die grinder wheel to it to make a slot in the top which you can then use a screw driver to turn it out.
    this guy has a pretty good video.
    Chy9853 likes this.
