Replacing Valve Cover Gasket
Discussion in 'General Tech and Maintenance' started by Cashizslick, Mar 29, 2004.
  1. Cashizslick
    Ok, i have to repalce my valve cover gasket.
    How can i tell what side is the "passenger side" so i dont put the thing in backwards [again?]. Also, got any tips for screwing the Valve Cover down again (so the washers are even?).
    - thanks in advance. (yes i searched)
  2. Cashizslick
    BUMP
  3. phunky.buddha
    Dallas / Fort Worth, TX
    The valve cover gasket is keyed... it only goes in one way. If the gasket isn't sitting completely in the groove without forcing it in, take it out and flip it around.
  4. Gen2Teg
    Gen2Teg Senior Member
    san francisco
    :ditto: :werd: :withstupid: its simple. make sure you torque the valve cover back down properly and use that red gasket maker stuff too. Shouldn't be a problem, its pretty simple.
  5. Cashizslick
    Just a question, can you expand on this?
    Thanks a lot guys - cash
  6. Slammed90Lude
    Slammed90Lude Senior Member
    milford, PA
    ie- go to the manual, follow the tightening pattern they give you and torque the bolts in the RIGHT order and to the correct torque spec
    you do have a helms right? shit i think even the chilten and haynes have this shit in them
  7. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    7 LBS-FT
    DO NOT over tighten them, if you do then you'll have a "How do I remove broken valvecover bolts" thread.
  8. E_SolSi
    never seen any of those before :lmao:
  9. Cashizslick
    Sorry, i dont have a helms, can you tell me the order to do it in???
  10. xj0hnx
    C.C.TX.
    There is no order for the valvecover, just remember...
    7 lbs-ft
    If it makes you feel better, you can do them all left to right at five pounds, and then go back and add two more.
  11. Slammed90Lude
    milford, PA
