mshields76
Hey guys I was searching for information on a problem I am having and came across this site so I thought I would see what you guys think. To start off with this is not a street car, the car has been turned into a old beater dirt track car so I couldnt tell you what year the car is but I was told that the engine and harness was a 2000 model. The motor was a v-tech but it was illegal in the class so we put a non v-tech head on the car and the car will not rev past 6800 rpm. The head has had some work done and the bottom end has been freshened up to say. I have no clue where to start on bypassing the rev-limiter or if you even can. And I am not sure what I could do with the v-tech part of the system since I am using a non v-tech head. We had a ecu built from a company in Maryland and the car will not even crank with it. I have just got involved so I am not sure what the problem is with that. I am just wondering if someone could give some good advice or maybe point me in some sort of direction. Thanks in advance
Ms
Ms
