rino liner?
Discussion in 'Body / Exterior / Interior / Cosmetics' started by paulsen, May 13, 2010.
  1. paulsen
    paulsen sponge of knowlege
    sac
    hi all, im building a project and was wondering if anyone knows or has heard of rino liner being painted?
  2. TurboMirage
    havent painted over it but used it to line the trunks of my cars. works great.
  3. paulsen
    sac
    if you dont mind, what brand did you use? i purchased some off brand at the local parts store, and im wondering about duribility,
  4. ZCRXmn
    ZCRXmn New Member
    I've used two different cheap brands on trucks, the better of the two was Plasticote brand. The other was Duplicolor I believe, I don't remember because I hated it...it had no "texture" to it at all and thats what I wanted it for. The Plasticote brand is really pretty rough so thats my choice, plus its cheap.
    I've painted over the Plasticote brand stuff with enamel paint and it seems to be working just fine. I'm sure that Rhino liner and most all the bedliners can be painted over, it should say on your can if you can paint it.
  5. TurboMirage
    duplicolor. i laid it on thick, it produced a nice candy shell :)
  6. paulsen
    sac
    how long ago did you paint over it? i believe i have hurkuliner available, and it didnt say anything about painting over it, ill have to double check to be sure,
  7. paulsen
    sac
    did you paint the same truck both times zcrxmn?
  8. 94H_Ex
    94H_Ex Under employed
    Florida
    I've seen once when some one painted the exterior of their car with rhino lining.
  9. Ethan
    Ethan Well-Known Member
    i was thinking about doing the whole inside and underneath my hatch while i have it striped down.
  10. 94H_Ex
    Florida
    If you have it completely stripped down to nothing BUT the shell. I might do it on the under side, maybe no so much the interior though.
  11. George777
    George777 ^^ Likes Bewbies
    With your mom
    I know with the spray on liner from some shops, you can tint the material before it is sprayed to have it be whatever color you want. Don't know if that is an option for you, or if there is a shop near you that offers that service, but it might be worth looking into if it is going to be something that you hold on to for a while.
    I've seen people spray their fuel tanks on their big rigs to keep rocks, sand, salt, etc. from eating away at the finish or damaging their tanks. It took a couple times of seeing it to get used to, but I suppose it serves its purpose in the long run.
  12. ZCRXmn
    ZCRXmn New Member
    No, I used the smooth liner on one truck and the rough on another. Its not that the Duplicolor was bad, just not the rough texture I wanted. I used some of the Duplicolor on my bumper on my Durango and liked it on that. It really depends on what you want it to look like and the use of the surface. The rough texture will probably be a little more durable but much harder to clean if thats an issue.
  13. TurboRex90
    TurboRex90 Golden EG
    Maryland
  14. E_SolSi
    that actually looks pretty good (at least in the picture)
  15. TurboRex90
    Maryland
    Yeah, i searched Rhino liner to see if i could find like ghetto sprayed cars with it for laughs, but came across that instead. I even saw some engine bays in black, really clean too.
  16. paulsen
    sac
    thanks for all the info everybody and the pics too, on the smooth duplicolor liner, how was the finish, flat?semi gloss?
  17. splashofpaint
    splashofpaint New Member
    canada
    rinoliner can be painted after 24-48 hrs cure time has to be red scratch padded befor paint is applied
  18. Ethan
    i just decided at work today i was gonna do my bay with it also... guess ill see how it goes! hatch is gonna be sick!
  19. paulsen
    sac
    sweet is that just a red scouring pad? splashof paint
  20. paulsen
    sac
    sweet post pics when you get it done i would like to see how it turns out, got mie sanded and ready today
