Rough Driving
Discussion in 'General Tech and Maintenance' started by vtecsir1, Jan 17, 2003.
  1. vtecsir1
    vtecsir1 Senior Member
    Orlando, FL
    i swapped in a vx motor in place of my cx, the only sensors not hooked up are the vtec solenoid and the oil pressure. the car runs real rough and wont rev past 4k rpm, what could this be vtec and oil? i checked plugs and wires. it is also running very rich, i am running the vx ecu.
  2. Liquidblaze
    Liquidblaze Senior Member
    Huntsville, AL USA
    Why don't you just plug up the oil pressure and vtec solenoid and get it over with?
  3. vtecsir1
    Orlando, FL
    well if i had them on my harness i would, i have a stock cx harness
  4. chevy302dz
    chevy302dz Senior Member
    Is the ECU throwing any codes? If not then double check the wiring, if you're running rich and getting spark it's either to much fuel or not enough air assuming it's sensor related. If that all checks out then try timing and checking for a vac. leak.
