running rich-d16a1
Discussion in 'Integra' started by christoph1119, Feb 24, 2009.
  1. christoph1119
    christoph1119 New Member
    carlton, OR
    i just replaced my cylinder head and gasket,everything looks to be in time i cant figure it out it was fine before just over heating. can someone point me in the right direction?:mellow: also lacks power and bad fuel millage
  2. welfare
    welfare Ancient Member
    New York
    check and see if you hooked up your wiring correctly for your MAP and TPS sensors, the plugs are the same and if you get them backwards all sorts of weird things can happen. Also make sure that your vacuum line for your fuel pressure regulator is hooked up right.
