s13 tach not working
Discussion in 'Other Vehicle Discussions' started by VTECPOWER, Dec 1, 2005.
  1. VTECPOWER
    VTECPOWER Senior Member
    Winchester, VA
    I'm buying a 92 240sx w/ sr20det done, and the tach does not work, any ideas of why it may not work? The seller says it worked previous to swap.
    Any suggestions?
  2. reikoshea
    Dallas, TX
    do they have a vss?
  3. VTECPOWER
    Winchester, VA
    idk much about them, that's why im trying to learn, anybody know a good nissan site?
    Also isnt the vss for the speedo and not the tach?
  4. NissanNiNjA2nd
    NissanNiNjA2nd Senior Member
    cuz the stock tachs dont read the sr20 input.
    you have to unsoder some connections and then resoder some others
    I dont remember what off the top of my head.
  5. hondarin
    Texas; where else?
    apparently, you have to do some tachtical soldering. :p
  6. reikoshea
    Dallas, TX
    bad pun...and i dont know why i thought the vss had something to do with the tach. I really do know the dizzy sends that signal...
  7. VTECPOWER
    Winchester, VA
    So just re-wire some stuff?
    Is there any way to just swap out the entire cluster for the tach to work?
    And do you know where I can find some sort of diagram to re-wire it?
    And would this be re-wiring behind the cluster?
  8. Celerity
    Celerity Well-Known Member
    Start simple - at the signal wire on the dizzyitself. Then do a continuity test through the line to the gauge connector. Finally, check the gauge.
    The SR20 swap really shouldn't impact the tach unless the physical connection wasn't made. I have an SR20DE in stock form if you need reference. (1993)
  9. VTECPOWER
    Winchester, VA
    I'm more than likely buying an aftermarket tach along w/ boost gauge, autometer cobalt. Backlit LED which isnt bright like the others.
    So I will need to know which wire on the dizzy is the signal wire for the tachometer
  10. ripperbone
    ripperbone angry bear
    Oklahoma
    one way to find the wire is use a test light.
    hook the ground clip to the tach wire, hook up the power wires and ground wires up, and use the test light to find the wire that gives you rpm signal to the tach
  11. Celerity
    Cobalts, even when digital, are brightly lit around the trim just like the other gauges.
    The D-PIC gauge in Cobalt is neat though.
  12. VTECPOWER
    Winchester, VA
    haha, yeah, but i was just wondering if anyone know off hand which one was the signal wire.
    that is probably what i will have to do.
    anyone know what a good nissan - tech site is?
    I dont want to spend too much money on gauges, but I want something that looks good.
  13. ripperbone
    Oklahoma
    [​IMG] cobalt's are expensive gauges
  14. VTECPOWER
    Winchester, VA
    I looked them up and like $250 for tach, 60 for the boost.
  15. ripperbone
    Oklahoma
    [​IMG] they must have dropped in price, when I was looking at the cobalts the gauges were 199 each
  16. NissanNiNjA2nd
    Get a hole saw
    cut out the entire tach
    fit in a 4" analog 10k tach
    wire
    done.
  17. VTECPOWER
    Winchester, VA
    So, do you know the actual wiring that is needed to get the stock one to work, i dont want to cut out the stock one, also the water temp gauge doesnt work, i was told that the sr20det's don't have a temp sender? Is that correct?
  18. FirebirdSkylineZX28
    FirebirdSkylineZX28 Member
    Indianapolis indiana
    Might Want to ask at Indycarz.com/forums they might know something. Ya never know...
  19. TurboMirage
    why not try freshalloy or 240sxone?
  20. VTECPOWER
    Winchester, VA
    Are those some good nissan sites?
    thanks! that's what I was asking for!
