I've got a bunch of misc. parts laying around my garage that I want to put to use. My current project I'm working on is an LS/VTEC motor. I'm using a JDM B16A1 head. I have a Type R intake manifold, throttle body, fuel rail, and fuel injectors I want to use. I also have most of the sensors (TPS, MAP, etc) from the original B16A1 manifold. My concern though is with the fuel injectors. They are saturated fuel injectors. I am using the PW0 ECU (pre-OBD) which normally controls peak and hold injectors via a resister box. I need to know if it will be OK to connect the saturated injectors if I simply bypass the resister box. If this won't work, I will have to buy the appropriate injectors, but I want to try and save a little $$$$! If anyone can help, please do.
