what would cause a rythmic flashing of the check engine light in the guage cluster of a OBD0 Honda CRX? I have swapped a B16 in about 2 years ago, and this has never happened.
I am getting no codes at the ECU, but the CEL is flashing , and continues to do so until you turn off the car.
any ideas?
also, what is the possibility of radio interference or voltage spikes from a secondary ignition, voltage leak from the primary ignition, causing problems with my ECU, and/or my Mf2.?
I have the turbonetics full kit in the car, and i have had NO problems with my swap., but now, my ignition begins to break up after 7k rpm.
my car made 240 hp on the dyno, without having the ignition stability to rev past 7k.
I have been working with Jahame from turbonetics trying to find a solution, and he has sent me another MF2, and a Motec, but i can not get it to straighten out..
PLEASE help..
any ideas?
PLEASE help..
