Serious suspension problem
Discussion in 'Wheels / Suspension / Tires / Brakes' started by CRAZYEG9, Aug 23, 2005.
  1. CRAZYEG9
    CRAZYEG9 Senior Member
    The five boroughs
    I need to change out the old E.S. bushings that I put in previously for some new ones cause there worn. The problem is is that when I worked on the first lower control arm, I got every bolt off but that one bolt that goes throught the control arm into the cross-member would not come out. It just kept spinning. What do you think can be the problem and what should I do. I ain't trying to swap out no cross-member.
  2. Battle Pope
    Battle Pope New Member
    Southern Oregon Coast
    Sounds to me like the threads are stripped.
  3. pissedoffsol
    try mashing a screw driver in behind the head of the bolt... use it as a lever ad you wrench it out.
