Shaking in my steering at around 70mph
Discussion in 'Wheels / Suspension / Tires / Brakes' started by truoss, Feb 27, 2005.
  1. truoss
    truoss Senior Member
    When I hit around 70mph, something on the front end starts shaking. Not very badly, but it's not good! What could be causing this? I know my bearings are good, my axels are new, and I know my tires/wheels are balanced (both are new). What else could be wrong? thx
  2. MXDesa
    MXDesa Senior Member
    Queens, New York
    Lower ball joints or tie rod ends. Something u should check to make sure right away.
  3. TWISTEDIMAGE
    TWISTEDIMAGE Senior Member
    CASPER WYOMING
  4. tylonalsnifnfool
    tylonalsnifnfool Senior Member
    ny
    %90 od the time shakeing is just a wheel out of balance.
  5. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    jack your car up and grab the wheel at the top and the bottom and shake it should noe move then do the sides
  6. tylonalsnifnfool
    ny
    to check your ball joints jack it by the A arm them grad and shake the top and bottom. to check the tie rods you are supposed to have the weight of the car on the tire and shake it front and back.
  7. 69crx69
    69crx69 Member
    Wa
    who ever you got the tires from must have balanced them wrong. If you only get the shaking around 70mph then it is definatly that.
  8. E_SolSi
    :withstupid:
    might be an alignment issue .... but the first thing i would check is the balance
    could be something stupid like a weight fell off
  9. YouKnowWhoIBee
    YouKnowWhoIBee my avatar is better.
    Maryland
    what is the speed rating on them?
  10. bluenutz5
    bluenutz5 Senior Member
    chicago
    could be a warped rotor!!! thats wat happened to me.... check that out
  11. E_SolSi
    could be a dented rim
  12. d93sol
    d93sol Junior Member
    All these posts should answer you questions.
  13. b204dr
    b204dr Senior Member
    Minnesota
    engine mounts can cause shaking to at certain rev/speeds!
  14. PhyRe
    PhyRe Senior Member
    ct
    havin the same prob at about 70ish it just shakes back and forth lightly. but im almost positive its my tires, my steering wheel is cocked a lil to the left but drives straight. dunno if this is right or not but i heard someting about deflating a tire when off balanced and then pumpin it back up will fix it. it sounds to good to be trew but who knows
  15. b204dr
    Minnesota
    steering wheel cocked=bad alignment might drive straight but none the less bad-
    as long as the wheel is balances the tire psi wont make much difference
