Short Shifter Install..?
Discussion in 'General Tech and Maintenance' started by jdm538, Feb 2, 2003.
  1. jdm538
    jdm538 Junior Member
    I have a 93 hatch i want to install an STR short shifter but im not sure which way to put it in. i dont want to put it in backwards can anyone tell me which way its meant to be? is it supposed to angle towards the front of the car or the back?
  2. SixtySecondAssassin
    Austin, TX
    back
  3. ALLJDM
    ALLJDM Senior Member
    Tampa, FLorida
    You're kidding right? Weather you have a dual ebnd shifter or a single bend shifter, then you'll want the top part of the shifter pointing toward the back of the car. You'll probably need top remove a section of the exhaust to get to the underside of the shifter. Once y0u've done that, then all you need to do is remove some of the bolts that hold it in place.
  4. jdm538
