SI MINI ME into HF problems please help
CRX2NR18
well it ran okay for a week or so but now it idles at 1500 and dies down to 1000rpms every 2 sec or so. i unplug the TPS sensor and it runs fine, can anyone help me please im on the verge of sellin my car so help
TJ
what else could it be? vacum? im not getting any ECU codes... what are all the possibilities, i checked the vacum and its fine... so u think its the TPS? is there any possibilty my wiring keeps shortin out the TPS? cuz when i had my hf in there its TPS was bad also, u think my wiring is bad?
Do you mean the TPS was bad and your using the same one?
or are using a newer one and you think its gone bad again?
i had my HF TPS in there with my HF motor and it was bad, got an SI TB with newer TPS and it went bad (hf motor still) got a D16a6/z6 mini me, and a newer TPS and now its bad... i think they all had about 130-150k miles on them
