ef9civicgen4
if i buy a B16a1/sir1 and it comes with the stock sir axles, do i still need to make custom axles or will the sir axles work without modifing. also i an confused. if my conversion comes with all this what do i need to put it in a 1989 Honda Civic DX.
- Motor
- Cable Tranny (Y1, S1, J1)
- ECU (PR3, PW0)
- Axles with Half Shaft
- Shift Linkage
- Stock Motor Mounts
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
- Comes With All Sensors Needed
thanks if you can help.
- Motor
- ECU (PR3, PW0)
- Shift Linkage
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
