SIR2 B16A2 o2 sensor question
Discussion in 'General Tech and Maintenance' started by 93SIR2, Jun 18, 2005.
  1. 93SIR2
    93SIR2 Junior Member
    I have a SIRII B16A2 OBDI motor. Which oxygen sensor do I use?
  2. jamesA
    you have an obdI b16a SiR II, not a b16a2.
    What car is it going into? If it's going into an OBDII chassis use the O2 before the cat.
  3. 93SIR2
    93 Del Sol Si. Its been in, its just setting off o2 sensor codes now. I was just told I could use any 4 wire sensor from 92-95. Just seeing if thats true.
  4. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    You can use pretty much ANY four wire o2.
  5. pissedoffsol
    yep, your stock one or the one that came with the motor will both work.
    if you're throwing a code for it, the sensor it self is probably shot, or not plugged in. requires 0 wiring changes from what you had to the new motor
  6. 93SIR2
    Cool, works for me. Thanks for the replies.
