SIRII in 94 civic ex (OBD1)
Discussion in 'HYBRID -> EG-EK / DC' started by leonc, May 28, 2005.
  1. leonc
    leonc Senior Member
    Las Cruces
    Don't harass me about this. I have searched here and on the internet.
    I seized my motor due to flash flooding (in the desert, wierd). I need a swap that is complete so I can just drop it in and go.
    I was wondering what i need to be able to do this swap.
    I have come up with.
    Engine
    Tranmission (hydro)
    ECU
    Shift Linkage?
    Wiring Harness?
    Axles
    I know my harness already has vtec, so do i need another or can i use the stock one.
    What about the shift linkage? Can I use the stock one.
    If you have any information or links to places where i can purchase a complete swap (with no extra parts) please let me know.
    Leon
  2. VTECin5th
    VTECin5th Administrator
    Phoenix Az
    b16a2 into 94 civic Ex:
    Motor+tranny+obd1 ecu
    Use the b16 shiftlinkage.
    Use 94 Integra LS Axles or the 00 civic Si Axles.
    Get a 96-00 integra GSR or Type R harness. (Not a 94-95 harness).
    everyone will probly reply http://hmotorsonline.com
    try them, ive heard only good things.
    im not sure if you meant b16a2 or a Sir II b16, they are two different engines.
    The above is for the b16a2 swap from a 99-00 civic Si, going into 92-95 civic.
  3. leonc
    leonc Senior Member
    Las Cruces
    I would actually like it to be an SIRII
    thanks for the info, if anyone else has some please reply.
    Im pulling the siezed motor today.
  4. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Than you want a 94-95 GSR/DelSol vtec harness, or use yours, I'd use yours.
  5. VTECin5th
    Phoenix Az
    Did you edit the title? im sure it DID say b16a2 before? :huh:
  6. leonc
    leonc Senior Member
    Las Cruces
    I did edit the title. Sorry to confuse you.. lol
  7. leonc
    leonc Senior Member
    Las Cruces
    Can i use my axles from my d16z6 for a SiR II swap or do i need the axles from the swap? probally a dumb question but oh well
  8. CoreyR
    CoreyR Senior Member
    no you need B series axles. 94+ integra axles and intermediate shaft work.
  9. Teal_HB
    Teal_HB Member
    Portland, OR
    Or if you buy the complete from HMO then the axles it comes with work and so do the mounts, you just need a new throttle cable or make a bracket, because your D16 throttle cable won't work. And you also need 94-97 DOHC Vtec Del Sol radiator hoses to hook up you rad. I think your good from there.
  10. leonc
    leonc Senior Member
    Las Cruces
    what kind of throttle cable do i need? or does anyone sell throttle cable brackets for this swap?
  11. reckedracing
    reckedracing TTIWWOP VIP
    NY
    threadjack is progress
    how can you tell a SiR from an SiRII with 170 hp?
  12. adnoh
    adnoh Senior Member
    Ontario
    B16A Variants a-la-Hondaswap
  13. xj0hnx
    C.C.TX.
    Threadjack continued.
    Actually the reality of things is that SiR, and SiRII are just trim levels, availible at the same time, not model generations. so from 89-91 there are SiR's and SiRII's, from 92-95 there are SiR's and SiRII's, and same for 96-00. The II being the fully loaded B16A powered ones, and the SIR's being the equally powered, yet less optioned models.
  14. xj0hnx
    C.C.TX.
    Sorry, forgot the whole point. You can tell by...cream colored plugs instead of grey, thermostat housing, serial number, and IM.
  15. leonc
    leonc Senior Member
    Las Cruces
  16. VTECin5th
    Phoenix Az
    you can use the D series cable and modify the bracket to work.
  17. xj0hnx
    C.C.TX.
    Or use the DelSol throttle cable.
  18. Teal_HB
    Teal_HB Member
    Portland, OR
    inlinefour.com sells throttle cables or check a honda dealership for doch del sol one
