skunk 2 cams and gears
pistonkiller
i have a completely worked head skunk 2 everything. what is the best setting on my cam gears so i can get the best results out of them. thanks
That isn't something that we can just tell you. In order to set them well you need to put the car on the dyno and see what works best. On a side note, be careful with the Skunk2 valves/retainers, they will need to be lashed very frequently.
You will have to adjust the clearances between rocker arm and retainer much more often than with stock retainers.
You're right, but what I meant was that the Skunk2 retainers whift a lot causing a bigger gap in clearance.
