I have a question on skunk2.... were do they fall in the performace catagory or range...? or can you tell me what is the best out... dont want no cheap parts..
Skunk2's are good, but not so good. They have a bouncy ride effect and can effect the way you launch. Everytime when you are on high speeds and change gears, for instance like power shiftin or double clutchin, your car would bounce, causing loss of speed. When you launch, its going to create a bounce when you get the traction. If your on a tight budget, go with ground controls. But want really good suspension, go with Flightex. I have Flightex Type ST equiped on my civic. The best i ever felt.
