Smoke
Discussion in 'General Tech and Maintenance' started by haccord141, Jun 14, 2003.
  1. haccord141
    haccord141 Senior Member
    So Cali
    hey guys what does it mean when white smokes blows out the exhaust when driving, i need to know asap. it is not my car it is my friends car. thanks
    peace.
  2. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    It means you have an iternal leak of coolant aka, you probally have a blown head gasket.
  3. E_SolSi
  4. chevy302dz
    chevy302dz Senior Member
    Is there anti freeze in the oil or oil in the anti freeze? does the car only smoke when the engine is cold or at all times? How do the plugs look?
  5. BigJ
    There will be water/antifreeze in the oil if a blown headgasket. Check it, and if it seems milky at all, or creamy then you best be taking the head off.
  6. kbieth
    kbieth Junior Member
    GA
    mine did the same thing, trust me, instead of dumping all the money into taking the head off and shit, i just did a swap, cost a couple of extra bucks but well worth it. But the guys are right, thats a blown head gasket
  7. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    What?? you serious how does a headgasket end up costing more than a "swap"?? Check out and try to find the problem, once you found the problem, get the solution for it. Headgasket = 60 bucks from honda.
    Milan
  8. asmallsol
    Your so nieve, you totally forgot the cost of oil, antifreeze, and beer. Together that will cost you at least $30-40. lol
