twisted civic
I'm lookin for some advice from experienced solo'ers -
'00 civic - front strut brace, frt lwr tie bar, Agx frt struts, rr siR struts, teg frt sway bar, engine swap, ra1's, rr lwr tie bar, rr sway bar removed temporarily, have rear strut brace (not installed), a little negative camber and toe in to help turn in.
Since I put the motor in, the power is great but, my car naturally pushes a little more now.
I had to remove the rear sway bar temporarily because it wouldn't fit with the exhaust I'm currently using (couldn't use my other exhaust because the engine was way too loud).
I was thinking about going with some integra springs to stiffen things up.
Does anybody have any recommendations (other than put the rear sway bar back on, or learn to drive better) about how the car could be set up to push less and rotate more easily?
any help appreciated,
thanks,
thanks,
