Some B20 VTEC questions
Discussion in 'Engine Building' started by adnoh, Jan 25, 2006.
  1. adnoh
    adnoh Senior Member
    Ontario
    Hey guys,
    Throwin around the idea of turning my JDM B16A into a moderately built B20 VTEC. Have some questions regarding compression ratios.
    If I run the following OEM pistons, what would be my approximate compression ratio with a single head gasket?
    1. ITR pistons
    2. CTR pistons
    3. My B16A SiRII pistons
    Thanks...I'm a noob to the CRV/LS VTEC thing, so bare with me!
  2. brian11to1
    brian11to1 Senior Member
    You can not use ITR, CTR, PR3, P30, PR4 pistons in the B20. The B20 has 84mm bore where-as the ITR (all other B series) have 81mm.
    Also since you said "mildly built" B20Vtec, you may as well hit up arias or wiseco for forged pistons and eagle for forged rods. Not to mention you should get the block sleeved because if you raise compression, the stock sleeves will die.
    Otherwise, sitck the head on the block and dont expect to rev higher than 7200 (stock red line)...
    b20vtec.com best bet for information.
  3. adnoh
    adnoh Senior Member
    Ontario
    Oh......for some reason, I think I knew that already...
    So B18 Block it is!
    Sooo......lets revise this question a tad....
    Same question as above, but LS block instead of CRV block....!
    And I'm not planning on sleeving any block I get...it's just not necessary for my power goals, and not to mention, out of my budget.
    Thanks though...
  4. phunky.buddha
    Dallas / Fort Worth, TX
    No, the stock sleeves will NOT die with higher compression. I've said it a million times- the B20 blocks are NOT made of glass. You can run pretty much any naturally aspirated setup and quite a few boosted setups with the stock B20 sleeves without any issues.
  5. brian11to1
    Im sure thats with good tuning.
    Let's assume he doesnt tune, then he fucked. So...
  6. adnoh
    adnoh Senior Member
    Ontario
    Would it be more useful if I were to start a new thread, stating power goals, plans, budget, ect...?
  7. brian11to1
    dont start a new thread, just edit your first one.
  8. phunky.buddha
    If you don't tune, you're fucked on any block.
  9. MikeBergy
    MikeBergy Blah blah blah....
    Central Coast, CALI
    :werd: You better tune. you'll be glad you did.
    Edit, was going to say I have a bare b18 block, but see you are in Ontario. It'd be cheaper to just get one up there. Carry on.
