Specs on SOHC ZC...
dohch22a4
Does anyone know the bore, stroke, and compression ratio of the SOHC ZC? I looked at all the ZC entries in the reference section and they are all DOHC. Thanks in advance!
The compression should be the exact same as the D16A6. Both engines have the exact same bottom end and head casting.
