speed sensor wire / stock 90 crx dx
HCCAfan
i am looking for the speed sensor wire in a stock crx dx 5 speed. i dont know where to begin looking in this car, or even know the correct wiring color for it. the book says it might be blue or blue/white for a civic, but nothing for a rex. so if you know where it is and what color, please share!!
thanks.
It should get a signal from the the tranny to the back of the cluster (cable) then from the cluster to the ECU (wire).
find an OBD0 ecu pinout and find the VSS pin...that will be what you want.
[post=551800]Quoted post[/post]​
what color and where?
Tachometer/VSS=blue wire at dist, tach Pin A11 behind cluster gauges
It also might be pin B16 on the ecu.
