speed sensor
t3t4si
Member
Ok i have had a major issue with my speed sensor lately. Some times when i step on the gas and go to 8 grand my speedometer will flip the fu** out. I bounces all over the place then it just sits at 0 when im going down the road. I used to have this problem before but i unpluged the clip and took a wire brush to it to see if i could get a good connection. It worked, but now (5 months later) it sits at 0 all the time. I tried to take a brush to it but no success. I installed some indeglo gauges about 2 months ago and think that my gauges may have come unpluged from the cluster itself. I'm not sure, so if anyone knows what i need to do please let me know.
Thanks
sounds to me like you have a loose connection either behind the gauge cluster or the VSS in the tranny is bad
