speedometer acting crazy in cold weather need help.
Discussion in 'General Tech and Maintenance' started by mainstang, Oct 25, 2006.
  1. mainstang
    mainstang New Member
    I dont know what is causing it but I already changed the speedo sesor in the tranny. Is there something I can clean on the back of the speedo that will make it work. It will work for a second then just go to 100, then to 0, then to what ever speed it feels like.
  2. mainstang
    i read somewhere about checking the engines main ground. And checking the grounding on the cluster/speedo. Does anyone know where the ground for the cluster/speedo might be.
