speedometer issue
hatukazi
ambitious...but rubbish
:tisk:I have a 92 hatch with a 95 LS swap and my speedometer works off and on, I put a different speed sensor on it and this helped for about two hours and now its back to crappy again.
I need to get it working cuz I got way to many tickets already (damn LS toruqe)
O I got the same problem with the speedo. I have changed the same thing you have said u did with the speed sensor, have you checked to see if your connection is bad? or mayby your cluster gauge was bad from the start check it.. if all that is still good check to see if your wire are loose or has a bad connection.
