Splicing my gauge lights in
ZCpowerdSI
Member
Hey, just got 3 new gauges. I already wired all the lights together and am wondering where and which wire do I splice the light wire with?
Thanks
Anyone??? On the directions it says splice it with dash lights or the dimmer switch.. i just dont know which wire.
you can just splice it in through the headlight wire under the dashbut just sodier and shrink wrap them so they got a good connection
better off going through the dimmer imo. it would be easy to find if you have a wiring diagram, otherwise get a test light and pull out your dimmer switch and go to town. I don't think there are that many wires going to it.
I ran my power wire for my gauges from the power wire to my cluster, which is hot in run or on. . Its the solid yellow wire.
hey, so i wired them to the power wire for the cluster like Jizerd97 said and they're working now.
thanks for the help guys :thumbsup:
