Sportlines are F'in stupid
Discussion in 'Wheels / Suspension / Tires / Brakes' started by SolReaver, Dec 22, 2002.
  1. SolReaver
    SolReaver Senior Member
    I just installed my front suspension, sportline springs and tokico illuminas...The passenger side sits about half an inch higher than the driver side. Anyone have any idea what may be causing this?
  2. CRX-YEM
    Wallingford, CT
    sportlines, ok that doesn't explain jack shit.
    neuspeed makes a sportline, eibach makes a sportline.
    etc...
  3. SolReaver
  4. Havok
    Havok Senior Member
    Florida
    u sure it's not the adj shocks?
  5. SolReaver
    I dont think so- they are both on the same setting (5)...maybe after driving around a while the springs will settle.
  6. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    did you maybe get the wrong springs, maybe they are diffrent spring constants?
  7. Havok
    Havok Senior Member
    Florida
    My friend has some Sportlines (yours should be red) and after he got em put on, everything was fine...Well, his wheels rub the wheel well, but he has some Tenzo R 17's. No problems on his tho.
  8. htrcivic96sir
    htrcivic96sir Senior Member
    Rick-town VA
    jack the car and re seat the spring....<~ had the same prob, the spring wasnt all the way in the purch so just look in there and check them out....
  9. sportlinecrx
    sportlinecrx Banned
    i have had my eibach sportlines for about 4 or 5 months now and havent had any problems. i kinda doubt that the eibachs are causing the problem because they are very well made springs, unless of course they are defective...in which case, eibach would replace them.
  10. CRX-YEM
    Wallingford, CT
    but still it would of helped if we knew the manufacturer of the spring. if it's not seated correctly like htrcivic96sir said, I'd check to make sure you put the corect spring on the front and rear.
  11. Havok
    Havok Senior Member
    Florida
    Sportlines are only made by Eibach, they make two springs, Sportlines and Pro-Kits.
  12. htrcivic96sir
    Rick-town VA
    true that CRX-YEN.....but if you mixed um up that would definitly be your prob.......its kinda hard to mix them up though becuz the fronts are flat on top and the backs have smaller coils at the bottom
  13. pissedoffsol
    double check... that you didnt swap a front for a rear spring...
  14. phunky.buddha
    Dallas / Fort Worth, TX
    No- they make a LOT more than just Pro-Kits and Sportlines.
  15. Havok
    Havok Senior Member
    Florida
    I meant Eibach is the only company that has "Sportlines"
  16. phunky.buddha
    Yes, that part of your statement is true. :D
  17. ZC 89HATCH
    ZC 89HATCH Senior Member
    nor cal
    i have had no prob with my sportlines
  18. htrcivic96sir
    Rick-town VA
    <~ runs 2.50 inch Sprint springs.....no sag after 10,000 miles and they only cost me 110 bucks. :lol: nuthin like a cheap skate
  19. brc80
    brc80 Senior Member
    Southern California
    is the front and back mixed up
  20. Havok
    Havok Senior Member
    Florida
    :werd: I've seen it done before
    Hello and welcome to 5 posts ago.
