i have done this with out compresing the sping but it takes some time to do you can compress them on the car but it not that easy i have done but i dont suggest that you do it that way
I remove springs all the time without a spring compressor, but it's generally not safe unless you have everything set up to shoot off into the right kind of padding.
If your new springs are short enough, you won't need a spring compressor for installation. I would go ahead and rent one anyway, just in case.
