Ssautochrome slam twisted mani
Discussion in 'Civic and del Sol - EG and EK' started by EP3Hatch1987, Jul 28, 2009.
  1. EP3Hatch1987
    EP3Hatch1987 Meeeeooowww!!!!!
    Has anybody heard of anything wrong with the ssautochrome slam twisted manifold? Wanted 2 see if it was any good cause my manifold juss cracked and need a new 1 any input would help thanx
  2. klyph
    klyph Dismember VIP
    North Pole, AK
    Ya, what's wrong with them is that they crack.
  3. EP3Hatch1987
    So it wouldn't be worth it 2 buy it? If not what would be a good manifold 2 go? I'm trying 2 stay away from the cast iron manifolds..
  4. BrutalB83
    Rochester Hills, MI
    Why? Do you not like how they look?
    And if you want something that will last, then spend some money and get something name brand...
  5. EP3Hatch1987
    No don't like how they look.. And that's what I was asking what is a good named brand?
  6. serrilion
    serrilion In my own little world! VIP
    Vermont
    Eldelbrock is awesome, um there are others but I've herd alot about eldelbrock
  7. Briansol
    in the price point of the SSauto/ebay crap, you're only other option is a cast/log mani. anything else is going to cost significantly more money.
  8. EP3Hatch1987
    The ssautochrome 1 I was looking at is 300 and looks way better made then the cheaper 100 dollar 1.. But I don't really like the cast 1s and edelbrock makes that 1.. I found some rev hard race manifold for around 500
  9. klyph
    klyph Dismember VIP
    North Pole, AK
    You're better off with a nice handbuilt log mani. If you are cheap enough to consider ssautochrome, your setup wouldn't benefit from a ramhorn because it won't require the flow capacity. What size turbo are you running?
  10. EP3Hatch1987
  11. efhondakid
    Akron-Canton, Ohio
    I say just go with a cast log, if it works does it matter what it looks like? That or just weld up the one you have now.
  12. DESPAIN
    flower mound TX
    or get a ram horn mani....its worht the money
  13. klyph
    klyph Dismember VIP
    North Pole, AK
    How is a miniscule reduction of spool time worth hundreds of dollars more?
  14. nootrac22
    exeter pa
    besides ramhorns will crack, it a matter of when not if. Cast holds the heat much better and the welds are serious weak points. When you heat a metal (like welding) it anneals the metal which changes the molecular structure. Basically hardening the metal to the point that the heating and cooling will cause cracks. The cheaper they are the sooner they will crack.
  15. EP3Hatch1987
    The thing is I didn't crack on any of the flanges it cracked on 1 of the actual runners.. So maybe I can re-weld?
  16. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
  17. EP3Hatch1987
    I found a log manifold.. From straIghtlinespecialties.com
  18. EP3Hatch1987
    Honda mini log turbo manifold $395.00
    This is what I found what you Guys think? Don't know how 2 post pics but this is the description
    CNC machined steel flanges featuring our taper port head flange
    304ss runners
    TIG welded
    Backed w/ lifetime warranty against any cracking/defects
