i have an ef with b 16 swap all obd1, have spark ,fuel and static timing is right ran yesterday
just did the swap 3 days ago will not start this morning,
continuity tested distro and inj all works what are the odds that its the main relay any one have this prob please help
Does it turn over?
Do you still have spark and fuel?
Any error codes?
Check all plugs, ECU, and grounds. Go with the simple things first. On a side note: EF's did have a problem with the PGMFI relay that caused no starts.
