Starting Problem
S14Civic
Hey...I have a 98 civic Ex and im having a problem getting it to start....the battery is fine and the starter is fine too...I took the starter out of that car and put it on my other civic and it worked fine.....when i turn the key it will make a clicking noise but nothing happens....wont try to turn over or anything....any help would be greatly appreciated...thanks
alternator could be seized or your spark plugs are full of oil clean those makes sure your getting fire
got the car fixed :) turned out to be something simple....the wire between the battery and the starter was loose :( ...thanks for the help though ......lesson learned....always start from the basics
