steering wheel
mygsr
Member
i have a 96 integra SRS the car was crashed and the air bags went off i would like to put a momo steering wheel non SRS how can i have only th/e passanger air bags and with the momo steering whele
I would assume just go ahead and connect a passenger airbag and leave the connection for the drivers side dangling (out of the way of course). Check wiring diagrams or call up Acura to see if a drivers side airbag needs to be installed for the passenger side to work (I dont see why they would run one airbag through another, but worth a check).
I don't know the value, but you can cheat the airbag sensor with a resistor- just like you can cheat the seatbelt sensor on most cars.
To install an aftermarket wheel, all you need is a hub adapter to fit the wheel brand you want- then bolt it all up.
