stock civic radiator???
Discussion in 'HYBRID -> EG-EK / DC' started by xisco44, May 21, 2005.
  1. xisco44
    xisco44 Junior Member
    hi im about to swap a b18a1 into my civic eg8 im missing the axles where can i get them for cheap, also my mechanic is asking me to put an aftermarket radiator on my (civic EL motor d15 with carburator latin america) he says that if i use my stock raidator with the swap the car is going to overheat how true is this.
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Get the axles from a pre 93 Integra if you have the halfshaft from the motor, or if you don't have the halfshaft, you can get the axle halfshafts from a 94+ Integra.
    As for teh radiator, I'd replace that one, but an aftermarket one isn't nescessary, just find a DelSol (possibly called a CRX where you're at) with a DOHC, or an Integra, and make a couple brackets to hold it in.
  3. xisco44
    hi thanks for the fast reply a friend of mine has a stock ITR radiator that he is willing to sell me for cheap but i dont know if can fit on the car because i have the radiator from the a/c.
  4. xj0hnx
    C.C.TX.
    Even with A/C you will have plenty of room. I have a B series and A/C the compressor isn't there, but the fan and condensor are where the Integra radiator would be.
  5. xisco44
    i would like to keep my a/C radiator are you sure that there is room for a huge ITR radiator on a civic eg8 chasis?
  6. xj0hnx
    C.C.TX.
    Not if you want to keep teh condensor, you should go with a DelSol vtec one, or a Fluidyne/Koyo style one like the one pictured.
  7. xisco44
    hi i would put a double panel radiator ;D thanks
    b16a1 pistons pr3
    93 ls transmission
    stock cam, stock head
    gsr stock header
    rim 15 190 50 r15 treadware 40 toyo ra1
    stock clutch
    2.5 exhaust
    universal muffler
    SRI
    p28 ecu
    how much whp should i be expecting and 1/4 mile time on a civic 92 4 door at sea level
  8. sohcslammer
    sohcslammer Senior Member
    Bay Area
    WHP - 140 - 145
    1/4 mile time with a GOOD driver - high 15s to low 16s.
